idle issue....
idle issue....
Hey I am new to this site and need advice on my truck here is the story...
So I did a complete rebuild on my 1996 dodge ram 1500 5.2. Once it was finally done and put it back it in it fired right up no problems but when it warms up the idle fluctuates for a couple minutes then dies it's been about 2 months now I have replaced.......all vacuum lines, my tps, my iac, my map, crankshaft sensor, pick up sensor, water temp sensor, intake manifold air temp sensor, both o2 sensors...it's got the proper fuel pressure and no check engine lights..if you have any ideas at all please let me know thank you.
i was going to guess a vac leak also. try to make sure the intake bolts are torque still and also make sure the throttle body bolts are good and tight. if still does it then take some carb cleaner and shoot it around where gaskets would be and listen for a change in idle, if u do u found the leak. pay particular attention to the rear of the intake manifold. around the dizzy. those gaskets are kinda hard to keep straight sometimes when u sit the intake on.
Trending Topics
