auto to manual?
#21
#23
hey you. yes it had the temp sensor in it... it also had factory lines without the check ball in it....
scooter. i droped a np435 in and the 97and newer flywheel works i just shimmed my crank sensor...
now the overdrive and temp codes... wile doing the swap. i noticed the wire harness had the plug for the clutch pedal sensor... it just had a plug with a wire looped back... now in theory i should be able to use a similar trick for the overdrive... being that i have an overdrive off switch... ?
for the temp sensor i guess i could just plug it in or make a port for it in the np435...?
I suppose you could try to trick the pcm into thinking there are readings coming from the sensors. As long as the signal they are supposed to send is a simple on/off and not a variable reading. So... Yes, I think that would work with the overdrive. The temp sensor could either be left alone, and it will forever throw that code, or you could indeed find a way to make it functional in your new trans.
#24
#25
I see. It is indeed. Hmmmm. Not sure how to fool that one. I didn't bother. My PCM throws codes for overdrive solenoid, trans temp and I think one or two other trans related items. My pcm and wiring is also from a 1994. I think my only solution would be to find a standard trans pcm. Preferably one without the California emissions flash and the "death flash"
#26
#27
can you elaborate on this.. have any pictures? Does your truck like to stall out when you push the clutch in sometimes?
#28
on my auto when i installed the manual pedals and master and slave. next to the fire wall under the dash, the wiring harness is held in place by a sheet metal bracket. the wiring connector for the clutch sensor... safety start up... was tucked away with a dummy plug with a wire looped back to it self... so i took out the dummy plug and plugged in the the clutch safety sensor...
