Headlight upgrade
Old 12-16-2014, 10:38 PM
Spillage's Avatar
Spillage
Spillage is offline
...you are not going to achieve the same light output as with the sports. You can't compare 2 bulbs vs four bulbs.
You use to be able to get 90/130 bulbs (off-road use only) that do a great job of lighting things up (with considerate height adjustment)... had some on a Suzuki Sierra 20yrs ago.
But they don't play nice with plastic lenses/housings :-/
Old 12-16-2014, 11:05 PM
zramsst's Avatar
zramsst
zramsst is offline
Originally Posted by oxymoron29
I'll be ordering the parts to do this conversion shortly. I already have the LMC harness installed for the 9004's currently on the truck (which made a pretty noticeable difference). I am buying the 9007 kit from LMC made for the "sport" model trucks so that each light is run off an individual relay. The only mod required to this harness would be the trigger switch, ie. changing the 9007 socket to a 9004 socket, which requires swapping the socket wires around. You'd have to extend the trigger wire as well to end up on the passenger side (it will come wired for the drivers side).
As said above if you are just looking for better light output do the relay kit, polish your lenses and most importantly buy some 80w/100w high output bulbs. I am currently running this setup and light output is drastically better than when I got the truck. I'm only interested in doing the dual beam swap to get rid of leaky headlights and for nice clear lenses to update the look of the front end.
Why would i have to extend trigger wire to passenger side? Is that the wire that goes to the headlight switch inside? Also why do the socket plugs have to be swapped?
Would the relay harness for non sport and ebay kit (http://m.ebay.com/itm/380807035946?nav=SEARCH) be as good as the 99+ sport relay harness and new housings?
I don't want to have to modify the 99+ sport relay harness but if all i have to do is extend a wire and swap plugs i can do that.
Old 12-17-2014, 06:00 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Each side has a 9007 and a 9004 bulb, I use the Piaa extreme white rated at 65/55 (listed as being equivalent to 120/110) times that by 4 and I have some good lighting watts. I have the 9004's wired up with relays and on a toggle switch so they don't work with the reg headlights. I can run with all four on low and I don't get flashed by others, I won't use them if I don't need to.
Old 12-17-2014, 11:26 PM
Spillage's Avatar
Spillage
Spillage is offline
Just another thing to add to my list of stuff to do.
Old 12-18-2014, 11:54 AM
merc225hp's Avatar
merc225hp
I went with factory housings DOT approved, bolt in (shy of cutting metal), and they are adjustable.
55077024AC right $243
55077025AC Left $243
Old 12-18-2014, 02:09 PM
oxymoron29's Avatar
oxymoron29
oxymoron29 is offline
Easiest way to setup the trigger wires for the 2x harnesses is to plug the original 9004 male connectors on the truck to the 9004 / 9007 female relay trigger connectors on the LMC harnesses. On a factory non-sport you only have 1 connector per side. The LMC kit assumes the 9007 harness is being used on a sport truck (which comes wired with 2 bulbs per side and therefore 2 connectors per side). They obviously want to make the kits as cheaply as possible so both trigger wires will be only long enough to reach the driver side bulbs. So on a non-sport truck that you are converting you will have to lengthen the 9007 trigger wire over to the passenger side and also swap the wires so it is wired as a 9004. Alternatively you can lengthen the 9004 LMC harness to the passenger side, however you will still need to swap the pins to 9004 orientation on the 9007 harness for the driver's side light.
Either way using this method you don't have any connectors unused / flopping around / corroding etc.
Wow you must have some cash to burn. They are $140 (US) shipped on ebay for a pair, complete. I picked up the lights, clear fogs w/ bulbs, headlight bulbs and a LMC harness harness for the price of one of those. Can't see them being any worse quality, most factory sports I've ever seen had hazed lights. My $0.02
Old 12-18-2014, 02:41 PM
merc225hp's Avatar
merc225hp
Just easier for me thats all, call Dodge parts, supply part numbers go to town the next day and pick up said parts. No shipping fee's, no duties (it's in the price already lol), no wait time and I get a Mopar part.
No hazing as of yet, I carry a bottle of water in the truck and a nice soft terry cloth to clean my lights with, no squeegees used here.
Quick Reply: Headlight upgrade
