Need some help with a few nagging issues...
Do not use silicon on the hose or on the thermostat housing where the hose goes. This can encourage leaks and get silicon into the cooling system. A thin layer on both sides of the paper gasket is all thats needed. Some thermostat gaskets come with adhesive on one side covered with white paper remove this paper before applying the RTV. I would not use cork for this gasket.
Back to the AC when using heat:
The AC will cycle in all settings except just front vents and just feet vents. This means the bi-level, the bi-level with def, and just def. It's so the moisture gets removed. Why it runs during bi-level face and feet is beyond me but it probably comes from the old days of "recirc" settings. Boy, I'm old if I remember that...
There are place's that rtv, thread sealant, pipe dope, thread tape are to be used and not used. A rubber hose going onto any metal/plastic fitting barbed or not should be done dry to achieve best sealing properties. Scuff and clean the metal part but don't use any sealant.
Good information - thanks!
Thanks for your input!
This is spot on! Thanks!
