2002 dodge ram build
#22
These guys will have about everything you would need.
http://www.performanceinjectionequip...Hold_Pics.html
#23
#24
So maybe the 5 speed swap, high compression pistons on stock bottom end, if it will hold up, port and polished heads, headers, injectors, intake and tune, gear the rear and blow the tired off, any suggestions
#26
#27
Yeah, you can get some 2.02 Clearwater or Odessa heads. They have an intake port size of 2.02, and the stock ones are 1.92, so that is an improvement. They are stronger castings that aren't nearly as prone to breaking as the stock ones.
Seems like the pre-magnum heads won't work. I think I read they bolt on a little differently, but can be adapted.
