Losing 100 Miles Per Tank
Speedo sensor is on the back of the tcase held on with a clamp . You mark the index , pull the sensor , and replace the gear inside to correct your mph . It pulls off the sensor . Google should provide your answers to which gear and tell you where they are available . I know with jeeps they went up quite a bit in price . Make sure your index marks line up when you reintall
Yes sir, thought about that one a little late.
I've thought about it, but I changed over to the 180* due to pinging after flashing the towing tune into my computer.
Bosch I believe, hard to remember. I changed them last winter, and was averaging 13 mpg. 14.5 freeway was the highest I recorded this last summer.
I warm it up sometimes in the summer because I see morning temps in the 30's pretty consistently through July. The truck is never garaged. My driving is a combo of highway town and rural driving, but that hasn't changed
My last HALF tank, I got about 70 miles until the gas light came on...
Try running a few tanks of 91 octane, you will notice an increase in power and better mileage. Just because these trucks are designed to run on 87 octane gas doesn`t mean that's ths best thing to use. My trucks (08 Ram 1500 4.7 and 2000 Ram 5.9 both 4x4)
run like crap on 87 octane gas and are way down on power. I run nothing but 91 octane gas in both trucks and there is a very noticeable difference in power and mileage.
Nothing but 91 here too . You get what you pay for . Only on my 2nd tank with this truck so far . First was 87 . Felt like an old dog to me . 2nd was 91 and now I barely touch the pedal to cruise up hills . Got at least 100 miles extra so far , and the 2nd tank was running much larger tires . 245/75/16 vs 275/60/20 .
The towing tune I am running requires 91. I have been running 91 for several months straight now....
Also, my understanding of octane is that the higher the octane number, the higher the temperatures inside the cylinder needs to be for detonation. This is why high compression motors or forced induction vehicles (turbos, superchargers) require a higher octane. When the cylinder compresses all that extra oxygen it heats up the fuel and air too fast causing pre-combusts known as "pinging" or "engine knock". Same effect with high compression motors... less space between head and cylinder, the oxygen and fuel heats up during compression, gets too hot before spark, and boom.. you have pre detonation, easily solved by a higher octane.
Say I am having the same issue running on no tune and 85 or 87 octane. I would assume increasing the octane with the colder temps out would cause me to not efficiently burn all the fuel/air in the cyl. getting worse gas mileage.
Now... I come hear to learn so please correct me if I am wrong, but i think I'm on the right track on the octane/combustion subject.
I'll prolly try this data logging first to see what my air/fuel ratio is.... but I guess I may try a warmer thermostat and revert back to stock tune for the rest of winter. kind of a bummer because I have grown attached to my towing tune and its shift points, but it's the only option that makes sense right now..
Maybe i'll try a 185* does someone make a 190*
