Transmission Problem!!
Okay guys I need some help, I'm getting frustrated here!! My truck is not wanting to drop back down to 1st gear. I replaced the speedo sensor towards the back of the transmission, and then I replaced the output speedo sensor that's towards the front of it, took it for a drive and it seemed to cure the problem. Got up went to work and was working like it should, left work and back to no first gear again. When I pulled the output speedo sensor out the magnet had some metal to it and some sludge but I wouldn't consider it bad by any means. I think my governor pressure sensor and solenoid is bad, but why does it sometimes work and other times it does not? Is there something else that may cause that?? Everytime I think I have it fixed, it works for a bit and then goes back to not shifting down to 1st gear, so my take offs ate like granny style!
Ahh , I'm not alone .
Tackling this today . I'm starting with cutting out the check valve on the trans line . Then moving to drop the pan , replace the GP solenoid and switch . While there , adjust the bands (front being a possible issue) I may drop the valve body and also check valves to make sure nothing is dirty or sticking .
My guess is the GP s&s will do it . If you do end up doing this , go to Cascade transmissions and buy the whole kit for $150ish . It will include the HD Borg Warner solenoid which is recommended
