o/d light comes on shortly after trans temp light comes on
Here is the rub, no trans shops will change just the TC. You will pay $800-900 for that and then if something else goes they will not stand behind their warranty. So they'll want to do a complete rebuild, or put in a reman trans.
Hopefully yours is something else. Mine, with the same symptom wast the TC. The good news is that you can't really hurt anything by driving it. It will just get horrible gas mileage without OD. Eventually the TC or trans will go though.
Good luck.
P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted <- This one is unrelated, and a separate problem.
P1740 TCC or O/D Solenoid Perf<- this may or may not be related. Have you cleared the codes since you changed the electronics? (I see this one fairly regularly, but, my trans shifts fine, TCC and O/D both work great.)
Yes cleared them, and I have one other thing when I changed the electronics there was this spacer on the pan acted as a gasket the trans parts place I bought my stuff from gave me a regular gasket I asked him if that spacer made a differencer(1 in thick roughly) and he said no so I didn't put it back on would that cause the trans to act up?
