Cold blooded SOB
Temp only at 3 this morning. Started right up on the second crank. Hasn't started below 10f for a long long time....so there's a plus there.
Still gave me a ka-crunk on the first try. New Crank sensor and + battery connector this weekend and it 'might' be back on the road.
BTW, if I've been driving for a while, stop and run into a store, I get the same ka-crunk on the 1st crank every 2 or 4 starts, warm or not. Still thinking crank sensor?
Don't forget about:
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
It does make a difference
Thanks Shak, I'll look at that in more detail.
I'll eventually get around to testing the fuel pressure, during warmer months, I get the back-fire on restart, but no stalling and bucking issues. I don't let it warm up in the driveway when it's already 60 outside. Was really hoping it was the Coolant temp sensor, when I replaced it in December all my issues went away, or so I thought. Came back in 30 or so days and enjoyed a mpg boost to boot.
Guess we'll see with the crank shaft sensor being replaced...
Once it's running, it runs, don't worry about it dying on me somewhere, it's the starting thats driving me nuts.
Replaced the busted terminal connector last night, fired right up this morning. I keep reading about crap Crank pos sensors, so ordered a Mopar OEM one...it's the last thing I can think of that may be causing a backfire on start...or the rev and stop of the engine after warming up for 5 -10 min.
Think I'll repair the Plenum and replace the clutch master cylinder assembly this summer and run it into the ground or sell it.
