Is my transmission dead
Old 01-21-2015, 11:23 PM
Cracksrubi's Avatar
Cracksrubi
Cracksrubi is offline
Default Is my transmission dead
The other day I hauled some wood 13 2x6s on a 16 foot trailer. It started doing long slow shifts then shifts to neutral to no gear/ losing gear during shift. Now when parked it will not creep in gear but if rev it it'll go just haven't drove further than my long driveway. Is it done I just want someone to confirm what I already dread. What do I need to do for a good towing rebuild. Already have a big cooler haven't installed yet
Old 01-22-2015, 12:04 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
What was the tranny fluid level? Color? Smell?
Old 01-22-2015, 08:03 AM
Cracksrubi's Avatar
Cracksrubi
Dark red, lightly toasted smell. Apparently I've been checking it wrong so at lunch today I'll let it warm up and check in neutral after running through the gears.
Old 01-22-2015, 01:34 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
Were you pulling that in O/D?
Old 01-22-2015, 02:24 PM
onegoodmason's Avatar
onegoodmason
onegoodmason is offline
That makes me think torque convertor . Maybe even a clogged filter .Time to pull the pan at least for a debris inspection .
Old 01-22-2015, 07:52 PM
Cracksrubi's Avatar
Cracksrubi
It was raining at lunch so no fluid check yet. I had od off. I may just pull the pan off to check everything out and put a new filter in just to see if that will help. I'm afraid it prolly a bad pump or something
Old 01-24-2015, 04:08 PM
Cracksrubi's Avatar
Cracksrubi
Fluid is a little dark but a little over full maybe next week I'll be able to get a filter and change it to try that
Quick Reply: Is my transmission dead
