Working on my 2nd Gen. Suggestions appreciated
I see it has new cap/rotor/plugs, but this will be the easiest time to switch to one with brass contacts if the existing cap is cheap. Check it out.
Yes, you need to replace the timing chain too. Right behind the water pump, plus like six more bolts. I wouldn't recommend the "advance timing" setting on some of the double roller chains- I used it and saw no discernible difference.
Then I'd recommend replacing the thermostat and temp sensor too, since the intake will be off anyway and system drained.
Go with a double roller, .25 chain pitch, set. Manufacturer doesn't really matter. I put the SA Gear in mine from Advance Auto. Works great, installed easy. Cloyes, crane, and other cam manufacturers make them as well... but, you pay for the name too. (although, I think any of them are within 5 bucks in price of each other.)
Don't forget the bypass hose on the intake. Take a look at the heater hose pipe that goes in the water pump. You need to reuse it if you can if not you need a new one. It also has a fitting that needs to be changed over to if i recall. Might want to put in a 180* stat in.
You need to pull the balancer and tc gear on the crank. Just make sure you have a puller and socket to fit the bolt.
It's not using that much coolant, just enough that I have to top it off every few weeks. generally the overflow never stays full.
i wish i did, i never seem to leave anything on the ground on the driveway or parked at work. i mean my plenum isnt fixed yet till monday, so im hoping maybe that can attribute to some of the loss. i can definitely link my oil loss to the plenum. My truck has never overheated *knocks on wood* so i don't worry about it too much. I usually check everything under my hood at least once at week even if im not worried about anything. Im also replacing the water pump as well. Its possible that the tubing in spots could have small leaks. There could be air pockets developing in their too and what not. I mean for all i know the overflow could be "overflowing" while driving. I think i might fill her up to the brim and drive around with the cap off back and forth to work one day and see if getting rid of potential air pockets helps out. Also i live in california so antifreeze is really useless around these parts. i usually fill it up after a flush with half and half, but i just top it off with water if it gets low.
alright i got the new plenum in, a new thermostat, new water pump, new double roller timing chain and a new upstream o2. Fresh oil change and coolant. Been a few days, she hasnt used a drop of either. Anyway im wondering if since everything is cherry now if i should use any additives or fuel system cleaner to clean out anything since the manifold is all pretty again.
