Trouble Cranking...
Old 03-11-2015, 11:10 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Hhhmm.... did it crank over at it's normal speed? That seems really strange.... Wonder if the PCM is annoyed about something, and it just isn't telling you.
  #22
Old 03-12-2015, 10:00 AM
2001Off-Road's Avatar
2001Off-Road
2001Off-Road is offline
HeyYou, it was definitely cranking at it's normal speed. It was cranking very strongly, it just wouldn't start. This morning, it started up just fine again. What is the PCM? Perhaps I need to check into that.
  #23
Old 03-12-2015, 10:09 AM
jkeaton is online now
Powertrain control module.
  #24
Old 03-12-2015, 10:12 AM
HeyYou is offline
Need to see what's missing when it won't start. The fact that it cranks normally, but won't start, and then starts right up after resetting the PCM, (disconnecting the battery) kinda makes me wonder......
  #25
Old 03-15-2015, 11:41 AM
ramdurangogirl9598's Avatar
ramdurangogirl9598
ramdurangogirl9598 is offline
I've been having the same issue since I got my truck in September. Loooong cranking before start unless recently ran. Almost as if loosing pressure. Passes pressure test, I've taken off the entire intake and throttle body and cleaned, replaced MAP sensor and fuel pump still same issue. Let me know what you find out.
Quick Reply: Trouble Cranking...
