1995 Dodge Ram Oil Pan Removal
Old 03-21-2015, 04:16 PM
cromeo68's Avatar
cromeo68
cromeo68 is offline
Default 1995 Dodge Ram Oil Pan Removal
I am stuck, I am trying to get the oil pan out of my 1995 Dodge Ram 1500, 5.2 AT 4WD, I got the bolts out, and it comes down some but the front of the oil pan is hitting the frame now and I cant get it to come down any further, I am no expert and now I am stuck, any advice anyone ?
Old 03-21-2015, 04:20 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
If you Jack the from up some you should be able to clear the front axle
Old 03-21-2015, 04:21 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
You might have to loosen the 2 big engine mount bolts and jack up the motor. It also might want to catch on the pickup tube also so be aware of that.
Edit: ^beat me to it!
Old 03-21-2015, 06:24 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Need to pull the starter, and dust shield off the trans as well, then you can drop the back down, pull it toward the rear of the truck some, and it will come right out. I didn't have to jack mine up at all. (but, mine sits a little higher stock too....)
Old 03-22-2015, 12:57 PM
cromeo68's Avatar
cromeo68
cromeo68 is offline
OK so the oil pan is loose now where is the safest place to jack against, I dont want to tear somethin up.
Old 03-22-2015, 01:27 PM
TiminSoCal's Avatar
TiminSoCal
TiminSoCal is offline
Jacking up the frame might let the axle
drop enough for the pan to clear.
I'd try this before unbolting the motor mounts
and jacking up the engine.
Old 03-22-2015, 08:56 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
i didnt have to jack anything up on my 01 1500. pan came right off. its a tight fit, but it works.
Old 03-23-2015, 02:42 AM
ryan0714's Avatar
ryan0714
ryan0714 is offline
x2 on that, i did however take the trans brace bracket off though
Old 03-30-2015, 06:21 AM
cromeo68's Avatar
cromeo68
cromeo68 is offline
Thumbs up Mission Accomplished
Got her done, I did have to lift the engine about an inch or so.
Thank you gentlemen for your input, Have a great day
Quick Reply: 1995 Dodge Ram Oil Pan Removal
