Best Starter
Best Starter
Hello,
I need to replace my starter I thought the battery was going bad because every time I would turn the key the engine would just click and not crank over. It would usually click three or four times before it starts. I wanted to know what the best re manufactured starter is, my three options are from autozone, orileys, or napa.
Its a 99 1500 with the 318.
Thanks
Thanks
I can relate. I've had such rotten luck with the discount houses that the only things I'll buy from them are fluids, filters, and spark plugs. I'm really lazy so I'll spend 150% of the time, effort, and money on a job if it brings a reasonable assurance of not having to do it again -- far too many times I've had to rip out a brand new (or newly remanufactured) part to warranty exchange it right after it's installed.
If you can wait on freight you might just order up the rebuild kit and save a bunch of money. It's not a guaranteed fix, but for the symptoms you describe it's the best guess there is.
Trending Topics
95% of the issues with starters are the contacts inside. If you can get yours off they sell kits to replace them. When i was looking for one for mine pep boys had an explanation of what was done with each option available. Some only got the contacts where others got mostly all new parts. Do your research!
