rough idle?
rough idle?
i have a 1994 ram 1500 with a 3.9. today i changed the plenum gasket. after i got everything back together it was idling rough. i unhooked the two vacuum lines on the passenger side of the intake manifold next to the pcv port. it seems to run better with the vacuum lines unhooked . what could cause this? map sensor?
Unstable idle is usually a vacuum leak, but, that tends to give you a high idle.
Cleaned your throttle body lately? Sometimes they get gunked up, and the IAC isn't as effective as it should be......
Could try a power balance test. Just disconnect one injector at a time, and see which one(s), if any, have a profound effect on idle.
have you ran the engine enough for it to relearn idle?
Disconnect that battery to reset the PCM after you changed the sensor? (and which one did you change? one wire, or two wire.)
Trending Topics
i did clean the throttle body when i changed the plenum gasket. it was a 2 wire sensor. i disconnected the battery when i changed the sensor. i have not even put 5 miles on it since i changed the plenum gasket or sensor. should i just try to drive it more? i will try the power balance test. could a bad injector cause that? should i change the iac valve? thanks
Having your injectors hooked up wrong would do it too. (its sequential fuel injection, so it DOES matter.) Might be something else you want to check.
You got the right sensor.
It *might* just need to re-learn..... take it for a drive, (someplace not real populated...) and see if it gets any better.
