2001 dodge sport 5.9 burning oil
Old 04-18-2015, 02:04 PM
dodgeforum3305's Avatar
dodgeforum3305
dodgeforum3305 is offline
Default 2001 dodge sport 5.9 burning oil
my 2001 truck puffs smoke at start up or whenever i step on the gas hard. valve seals ? Plenum gasket? or rings ? what do you think ?
thank you
Old 04-18-2015, 02:33 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Just a puff at startup is usually valve seals. If you have oil consumption issues, that's gonna be the plenum, and possibly PCV valve. (along with rings, but, that's expensive, so we won't talk about that. compression test will tell there.)
Check out the Plenum thread in the 2nd gen section.
Welcome to DF!
Old 04-19-2015, 01:01 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
If the smoke under hard acceleration is very pale blue like oil smoke, try changing the PCV valve with one from the dealership.
For the rest, pay attention to that HeyYou guy. He's pretty smart for a guy who drives a Dodge.
Old 04-19-2015, 08:28 AM
dodgeforum3305
thanks guys going to change pvc this week after that ill try the plenum plate and gasket.
Old 04-22-2015, 02:14 AM
Twistedtrax's Avatar
Twistedtrax
Twistedtrax is offline
i just changed my pvc in a 5.9 2001 gas, i was using a quart to about 50 miles, and now it doesnt use oil or smoke. but the trans wont shift fron 2--3 by itself now, lol
Old 04-23-2015, 01:03 PM
Brandontenold's Avatar
Brandontenold
Brandontenold is offline
Taking the throttle body off and not reinstalling the throttle kickdown cable correctly will cause this. been there done that!
Old 04-23-2015, 01:58 PM
schmidtp's Avatar
schmidtp
schmidtp is offline
Try the PDF in this thread. I had the same problem when I just reassembled my truck and this fixed it. * are "dodge talk" one word
http://www.*********.com/forums/show...ighlight=cable
Old 04-25-2015, 10:41 AM
dodgeforum3305
changed the pcv vavle value cover gaskets and plenum gasket yesterday 80% back together , the pcv is on the driver side valve cover what is the one on the passenger side called . i dont think its a pcv valve jsut a elbow of sorts . i broke mine while uninstalling it . intake was full with oil .
thanks for all the advice guys .
Old 04-25-2015, 02:08 PM
UnregisteredUser
Yep, it's just an elbow. NAPA calls it a "PCV System Elbow", P/N NOE 6301078, and it's less than five bucks. You should be able to find the official Chrysler nomenclature and part number in the appropriate parts manual, which is a handy thing to have on hand.
Old 04-28-2015, 09:11 AM
dodgeforum3305
well, got it all back together, still smokes a little but. check oil after a long ride didn't seem like it was burning any . might just be whats left in the exhaust system etc, burning off. we will see.
Quick Reply: 2001 dodge sport 5.9 burning oil
