Help with PA 3" BL
Help with PA 3" BL
I installed the 3" PA BL just to realize i forgot to remove the shift linkage. I then removed it and welded in the extra piece. Only problem being it doesnt fit? It's lined up 100% The part that goes by the firewall is in, the park that connects underneath to the torque shaft arm (I BELIEVE) is 3" too long now. What the heck did I do wrong besides not remove the shift linkage the first time!
I will definitely take pics today when I get home from work. I noticed an issue when I thought I was done and went to start the truck only to find it wouldn't start and it seemed as if the gear shift was jammed into gear and wouldn't budge. I got under the truck and removed the shift linkage rod and messed around a little and seemed to have free'd it up. I am able to get under the truck and put it in park and the truck starts now. I cut and welded the shift linkage rod and it's about 2 inches too long now. In the instructions it does say something about a pivot arm assembly bracket or something but it's for the 2002 models (although the kit says 99-01 rams) I think if I had that bracket it would line up right but at the same time I'm worried I bent something pretty bad that I shouldn't have. Although im not entirely sure. The locking bolt (thing) at the end of the shift linkage rod is rusted to hell so the spring won't compress to adjust. If the spring could compress it would definitely fit although what else would that mess with? I'm probably calling the dealership and getting a new linkage rod as well.
I emailed PA about it and gave the guy the rundown. He said it sounds like I need the drop down bracket for the shift linkage rod to attach to. The only thing that concerns me is it says for 2002 models in the instructions. The kit is made for 99-01 and I have an 01. Why would I need a bracket for the 2002? Have you or anybody ever heard of this?
Both pics were taken straight from the instructions from PA for the lift. The top one is the "Pivot Shaft Support Arm" which I apparently need a bracket to make it drop lower. In the second picture is about where my actual shift linkage sits at the arrow. Its slightly lower so I do kind of agree I may need the bracket. Im just concerned because I would think I would see more people having this issue possibly.
Trending Topics
