s&b air intake
Old 04-20-2015, 12:31 AM
BrandonBuc'em's Avatar
BrandonBuc'em
BrandonBuc'em is offline
Default s&b air intake
so i see that most guys recommend sticking with the stock intake and swap out the cheap filter with something higher quality.
what about this one?
http://www.sbfilters.com/index.php/d...75-1511-1.html
i personally hate the stock one because of that damn band that attaches it to the tb. its a real pain. this one also utilizes the stock air dam through the side of the fender. take a look and let me know what you guys think. thanks
Old 04-20-2015, 08:37 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
I don't know..... for 200 bucks, I can be pretty tolerant...... Not like I have to take the air box off all that often.
Old 04-20-2015, 09:43 AM
BrandonBuc'em
think i might be better off just buying a kn filter and call it a day?
Old 04-20-2015, 11:57 AM
HeyYou is offline
Yep. More money to spend on something that actually makes a difference.
Old 04-20-2015, 12:00 PM
mda8569's Avatar
mda8569
mda8569 is offline
I hated it enough to spend the money, lol.
Old 04-20-2015, 12:16 PM
alaskaguy's Avatar
alaskaguy
alaskaguy is offline
Buy the k&n kit for the $250 and be happy.
Old 04-20-2015, 06:02 PM
BrandonBuc'em
i will not being buying the k and n kit because its pulling air from inside the engine bay. the stock unit is pulling air from the air dam in the fender. thats why if i do buy a new intake it will be this unit cause it still pulls lower temp air from outside the engine bay unlike the k and n. i was hoping someone here had this s and b kit.
Old 04-20-2015, 08:03 PM
Spillage's Avatar
Spillage
Spillage is offline
i will not being buying the k and n kit because its pulling air from inside the engine bay...
Not if you remove the rubber baffle next to the radiator.
Heck, you could cut a small scoop into the hood above the filter.
Old 04-20-2015, 08:10 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Search around on the Dakota forums. The difference in temp of the air. Once moving. Is just a couple degrees. completely neglible.
The main benefit of the stock style is it is very well protected from water/mud/ debris over there in the fender.
I just put a 14x3 on my truck. Sounds awesome. Still runs great.
Old 04-20-2015, 08:13 PM
Spillage's Avatar
Spillage
Spillage is offline
That is true... it depends on the intended use.
Quick Reply: s&b air intake
