Make Mine a 5.9
Make Mine a 5.9
Good article on Hot Rod about building a low buck 5.9 that makes 400HP.
http://www.hotrod.com/how-to/engine/...ke-mine-a-5-9/
I like what they did to the engine and it really shows just how good the EQ heads are right out of the box.
PS: Mods sorry if this is in the wrong area. It's tech but I don't know if it should be here or in another area. Plz move if needed.
I believe the Indy "X" heads have a slight performance advantage over the eq. Both good heads! Have seen dyno results up to 500 hp with them in a magnum motor. Rhs first came out with these but are now available through Indy.
http://www.indyheads.com/lax.html
