10-lug to 8 -lug conversion
Has anyone have any experience in such a conversion?
I can get front axle from Newer Ram 5500.
How difficult be to put under 2nd Gen Ram?
They are 10-lug pattern.
Can I just redrill hub for the right bolt pattern, change rotor and put 8 lug wheel?
What about suspension mounts?
Thanks for any info
Thanks for any info
Does it use the same suspension style? (4-link, and track bar?)
Width is ok, mounting it might require some fab work though..... No clue how you would change it over to 8 lug.... can you get the rear axle too? (it would have a matched gear ratio as well, which, currently, I do NOT think is the case.)
Trending Topics
