ABS or brakes need help
Ok let me start with all brakes are good wheel cylinders on rear new. I did have ABS and brake lights on put a new to me module on the ABS system lights go off now. Now brake peddle when applied feels good then gets hard and the rear feels like it wants to lock up. I can let off and apply brakes again they seem fine Speedo working right from zero. I can unplug the module the plug that goes to the brake line block for the lack of a better term. Brakes work just fine please help thanks
Yeah that was never a problem it first started I was running down the road bout 75 mph and the lights came on ABS and brake I changed the rear sensor didn't change it put the old one back in still acting up I unplugged the wire going to the aluminum block where all the lines run in and out works great then I plug it in and it goes to crap but the two lights stay on. I can't stand a light on
Trending Topics
