Rough Idle,no temp gauge and oil pressure gauge issue
Hey guys hopefully some can shed some light on my situation
Have a 2000 Ram 2500 5.9 gas I just got this thing 2 weeks ago with what the seller said was a bad trans. Turns out it was the governor pressure solenoid. It had codes for 3 misfires so i figured id throw a tune up on it because it sat for 2 years. Long story short I had to replace the distributor because the last person broke the ears off for the cap screws. So i pulled the intake to do the gasket as well because it was shot. I put the dist back in the way it came out and put the new gaskets and intake back in. The truck fires up but runs rough and when test driving it i noticed the temp gauge wasnt working and the check gauges light came on and the oil pressure was at zero. I shut it off for a minute started it again and the oil pressure went up to about 50 and just stayed there. Doesnt move when i rev it at all. I hooked my scanner up and the readings i got are
ECT 55 DEGREES
MAP 12.1
TPS 11
i havent tested the oil pressure with a gauge yet. I read somewhere that MAP shouldnt be higher than 11??
I could use some help with this for sure. What do you guys think?
Thanks!
ECT 55 DEGREES
MAP 12.1
TPS 11
Thanks!
Fuel sync. Needs to be pretty close for the injectors to be properly timed. Distributor actually has very little to do with ignition timing. (ironic, eh?)
Temp gauge gets its cue from the PCM, via the central timer module. (basically just a hub, on a little network.) Oil pressure gauge is highly likely to be the sending unit.
You can try a cluster test, just hold in the trip-reset button, and turn the ignition on. (don't start the engine.) Should mechanically test all the gauges, just watch for 'em to sweep.
