If I got the adjustment in the general area would the self adjuster if working correctly adjust the rest of the way to were they need to be? I have no dragging and the ebrake works good do I know they're catching. Just want to know if I was close if I'm ok .
How's your brake pedal height? If you are comfy with it, leave it. If it seems to go a little far before anything starts to happen, tighten up the rears a bit.
Everything seems fine. I just didn't know if I left it if it would cause the front to wear quicker than normal. As I said the height is good they're not spongy and the ebrake gets tights at about half way pressed and holds tight. Even on the test run I'd start to press the brake and as soon as I pressed u could feel the brakes start to engage.
Take it for a drive, and see what you think. Sometimes, actually driving it will help 'set things in place', and a bit more adjustment will be in order.
