Where do these go?!?
Old 05-29-2015, 03:28 PM
adlm's Avatar
adlm
adlm is offline
Default Where do these go?!?
I am just finishing up the work on my 98 ram. I replaced both heads, put the Hughes kit on the plenum, and replaced the timing chain and oil pan gasket. Now, I have everything back in place, but there's these two bolts left over!
I know this is a long shot, but does anyone have a clue what I left these out of? I have gone through the parts manual, but don't see any bolts this small anywhere. They have a 9/16 head on them, and they are only 1" long total (including head). Where did I go wrong?
The two leftover bolts after all else is in place.
Old 05-29-2015, 05:40 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
Maybe ground straps on back of head, transmission filler tube, oil tube, coolant tube, or fuel rail.
Old 05-29-2015, 06:48 PM
beeker's Avatar
beeker
beeker is offline
^this, or coil bracket if.
Old 05-29-2015, 11:00 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Brackets that attach from the intake manifold to ac compressor and/or alternator
Old 05-30-2015, 11:22 AM
Moparite's Avatar
Moparite
Moparite is offline
All good suggestions, Just look at everything it shouldn't be to hard to figure it out. Where they cleaned? Usually the hardware on the lower end gets all the dirt/grease.
Old 05-30-2015, 03:01 PM
adlm's Avatar
adlm
adlm is offline
Thanks for the input. I'm about to go out and check it out. No, they are not cleaned. This is exactly how they looked when I pulled them. They are the same size as all the bolts that attached things to the heads on the front side, just a lot shorter. So, I'm guessing ground straps on the back side. Should find out soon enough. Thanks again!
Old 05-30-2015, 07:18 PM
jrox44's Avatar
jrox44
jrox44 is offline
The color of the bolts suggests they've been soaking in years of antifreeze
Old 05-30-2015, 07:46 PM
adlm's Avatar
adlm
adlm is offline
Ding Ding Ding Ding!!!! We have a winner!!!
It was ground straps on the back of the heads. I kept going over everything of the front side of the engine, I forgot about the back side. Thanks everyone for helping me out, I was about to go nuts!
The color is a little off on the pic, that's what's making them look like they've been in antifreeze. For reference, I have them sitting on a black piece of construction paper for the pic.
