starting problems
Old 06-25-2015, 12:30 PM
hemi7700's Avatar
hemi7700
hemi7700 is offline
Default starting problems
i have a 1997 dodge ram 2500 diesel recently put a new cab on the truck. now that I have it all put back together it will not start. there is power at the starter and solenoids and are all working fine. when ignition is turned the dash turns on but doesn't even try to start the truck. also when solenoid is crossed still nothing at starter. any suggestions? thanks
Old 06-25-2015, 02:37 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
Starter go bad? Is it bolted on tight? Might want to check your engine grounds as well.
Quick Reply: starting problems
