no bus pcm is good help
06-30-2015, 07:26 PM
on
I have a 1999 dodge ram 1500 4x4 with a 5.9 pcm is good (tried on another vehicle) but keep getting no bus no gauges will turn over grounds are good is there anything I should do or check or any procedures thanks
06-30-2015, 09:23 PM
Dodge Forum Administrator
Will a scanner talk to it?
06-30-2015, 09:41 PM
on
No communication to the scanner
06-30-2015, 09:47 PM
I would suspect a failed central timer module then. That's how everything on the truck communicates.
06-30-2015, 09:54 PM
on
06-30-2015, 10:34 PM
Get the service manual for your truck
here. There is a component locator in section 8W. that'll tell ya where it is, and may even have some test procedures.
07-02-2015, 12:40 PM
I'm confused. Are you trying to install a used PCM onto a 1999 Dodge Ram 5.9 gas motor 4x4 truck or swap the PCM from a 1999 Dodge Ram 5.9 gas motor 4x4 truck onto another vehicle? Please explain further with additional details, as there are a lot of PCM differences for the gen 2 trucks.
07-02-2015, 09:54 PM
on
Pcm is good it is on the truck just tried on another to make sure update runs when you have a scan tool hooked up to it dies when unplugged and ideas
07-04-2015, 01:12 AM
on
Anyone only runs with scan tool hooked up dies when taken off I'm lost
07-04-2015, 10:20 AM
Check power feeds and grounds for the PCM.
