What are the pros and cons of removing the PCV and crank vent and putting in a breather or catch can with breather?
PCV system actually helps with ring seal. It doesn't rob any power, has no deleterious affects on performance, there is zero reason to remove it, and put in place a system that vents to the atmosphere......
Thank you. I didn't want to go through the trouble of repairing the plenum when I do to have an overactive PCV cause other issues and dirty up my new plenum
Is their a write up for a rear main change without dropping the tranny? I heard it's possible with these motors?
Also what's the proper way to run seafoam through these trucks? I need a way to clean the valves and such without pulling the heads after the plenum blew
