My ram truck
Old 07-03-2015, 09:01 AM
Khris1994's Avatar
Khris1994
Khris1994 is offline
Default My ram truck
Well. This is technically my girlfriends. I've been doing work on it for 3 years now. I shattered the rear u-joint once and shattered the tcase tail housing. Its been in 2 accidents. 1 was the previous owner. And the other a lady in an f150 pulled out in front of my girlfriend and she tboned her. At 40mph all I had to do is replace the bumper I currently am in the process of a plenum repair but with an 01 intake and kegger mod :0 I need to fix my "wild vents" as someone named it. Eventually getting headers from summit and a Gibson super truck exhaust. With a magma flow cat. High flow water pump. 180f stat. Has oversized 8mm spark wires for the pending coil change to a 42000v coil on champion copper racing plugs unless someone suggests better plugs. Also does anyone know why the truck has a 53 sticker on the frame?
Old 07-03-2015, 09:39 AM
Khris1994's Avatar
Khris1994
driver side. papers say 97 but the door says 96.
a little frame rust motor eventually to be turned into a project for a mud buggy
passenger side
rear axle and what i was told is a 6 inch lift. its a stiff ride and needs shocks though
soon to go in after parts are order. going from 96 intake with center plane to an 01 intake.
Old 07-03-2015, 09:55 AM
Khris1994's Avatar
Khris1994
i guess something i should have looked into. anyone know the tap thread for the second temp gauge for the water sensor? or can i just run without the gauge sensor and screw the pcm sensor in the hole?
Old 07-03-2015, 01:32 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
I believe it's 1/4-18 NPT. I did the same thing on a 99' intake.
Old 07-03-2015, 03:01 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Those are 2" blocks in the back. The lower block with the 'arm' hanging out of it is stock. Those are the bump-stops.
What's the front look like? (suspension.)
Old 07-03-2015, 03:10 PM
Khris1994's Avatar
Khris1994
I'll have to take a picture tomorrow. I think it's got added leafs.
Old 07-03-2015, 03:11 PM
Khris1994's Avatar
Khris1994
And larger springs in the front.
Old 07-03-2015, 03:17 PM
HeyYou is offline
Does look that way.... I think stock was only three or four....
Old 07-03-2015, 04:07 PM
Khris1994's Avatar
Khris1994
That would explain the rough ride... I want to swap for lifted leafs but don't know what to buy as I haven't done anything with suspension before. And don't know if I would have to mod anything
Old 07-03-2015, 05:41 PM
Khris1994's Avatar
Khris1994
Attempt to post front suspension from phone
Edit:didn't work
Quick Reply: My ram truck
