Catalytic converter
If you hearing some sort of a rattle from the catalytic converter, then its dead, get a new one. If your getting a fluctuating air exhaust sort of sound, check your idle, if your idle isn't consistent, then i wouldn't be surprised if its misfiring or a sensor is out. Do you get any codes? is the sound coming just from the your exhaust or is the truck shaking? need more details man
I think he's saying he has a 2 wheel drive Dodge ram with a 5.9 gas motor. I believe he's asking if the knocking sound (that he hears through his exhaust) his truck is making is his catalytic converter, or if he's hearing his engine making a noise and the noise is coming through the exhaust system.
My cat is definitely bad. But it doesn't affect my performance. I can hear it rattling when I start it up cold. It's not affecting anything so I didn't fix it yet. .. I think the honey comb loose from the mounts. But my suggestion would be crawl underneith your truck and bang on the cat with a rubber hammer . You'll know right away if it's loose inside
