help me straighten my axle
Old 08-15-2015, 07:51 PM
cutthroatxxx's Avatar
cutthroatxxx
cutthroatxxx is offline
Default help me straighten my axle
Im trying to figure out the best way to get my rear axle straightened out.You might of read me post about this b4.But when I had my accident the driverside rear axle went towards the rear of the bed.The blocks went forward.&rear U bolt got broke...causing it to bull away from the od unit breaking off@the t case & the ear om the motor mount bending. I need help on best course of action to take on fixing the axle.The rest I think I have.
Old 08-15-2015, 08:03 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,174 Likes on 2,927 Posts
Support that side of the truck on a jack, to the frame. Jack it up to take the weight off the spring. (just enough to lift the tire a quarter inch off the ground.Take off the existing u-bolts. Reposition everything so it is where it needs to be. Lower the truck just enough so there is a wee bit o' weight on the spring. Install new u-bolts. Tighten em up, remove the jack, check 'em again.
Old 08-15-2015, 08:15 PM
cutthroatxxx
Thanks, caere can I get the correct u bolts
Old 08-16-2015, 10:36 AM
Moparite's Avatar
Moparite
Moparite is offline
Get the correct measurements off your old ones than call around to local parts houses. Fastenal or anyone who deals in hardware can get them.
Old 08-16-2015, 10:46 AM
cutthroatxxx
Does the bolt thats ontop of that piece of plate do anything?There's like a knot on it and I didn't know if I should just take will do it or for runs through all of those pieces?
Old 08-16-2015, 10:48 AM
cutthroatxxx
Btw damn tow co stole my aluminium racing jack ain't that a bi#@&
Old 08-16-2015, 12:04 PM
HeyYou is offline
yeah, that's a bolt that runs thru the spring, and holds things in place. If it ain't broke, don't fix it.
Old 08-17-2015, 01:43 PM
cutthroatxxx
So basically...I jack the truck up from the leaf springs &pull the axle back to where it belongs?
Old 08-17-2015, 07:42 PM
HeyYou is offline
Don't jack up on the spring, jack the truck up by the frame. Otherwise, yep.
Old 08-22-2015, 02:34 PM
cutthroatxxx
Should I pull my t case or the od unit b4 I do this?
Quick Reply: help me straighten my axle
