Pops thur intake, and bogs . First geat only
2001 Dodge 1500 4x4 with 360.
Issue: When you stomp on the gas it pops back thur the intake and bogs. If you put the selector in 2 and stomp on the gas. It takes off with no poping, back or bogging. If you put the selector in R and stomp on the gas it will smoke the rear tires. If you come to a complete stop and let the tranny come into first and stomp on it it pops back . The only gear it does it in is 1st.
Things that have been changed: computer,fuel injectors, cap and wires and plugs,cam sensor, fuel pump.
Please help nothing seems to stop this. And no one seems to know why it is doing it.
Just keep throwing money at it with no succes.
From a dead stop. A fairly fast take off it will pop thur the intake. Although if put in second, with the same type of take off it dos not do it. or in reverse. No, I'm not slamming it to the floor. Now if you take it real easy or sart in second then **** to drive it does not do it. Or if you put it in 1st and do the same take off it will not pop. ONLY in drive.
Trending Topics
