Original PCV valve. I ran seafoam after I fixed the plenum. I'm just kinda hoping it's not rings... I ran about a quarter bottle. Should I try running more?
Of course, I still use oil badly too. Mine doesn't smoke though...... no puddles on the ground. The oil just 'disappears'. Got a little better after the plenum fix, but, I highly suspect rings as well.
Damn. After I fixed the plenum too. I'll try more seafoam. If no fix I guess I'm gunna be truckless. I can try a cylinder pressure check right? That would tell me?
