1999 sport headlight swap 2 bulbs to 1
Ok, I got tired of the yellowed lens covers on the 1999 sport quad 4x4. I found some replacement headlights only from carports.com and they said they were for a sport. It also says they are not for a sport which I realized when I see they have only one bulb instead of two. The bulb is the outside bulb. So I have one plug to the inside bulb I am not using. I understand the 1999 sport used a high/low beam on the interior bulb and a high beam only on the outer one. Can I move the high low to the outer and make this work? Or can I make this work at all. I found a plug that take two plugs and makes them one. Would that work with the right bulb?
Have you already bought the? I would search for some replacement sport headlights with the 2 bulbs. You will lose a LOT of light going to the non sport style. The single bulbs suck.
here ya go
http://www.am-autoparts.com/2001/Dod...80/380897.html
here ya go
Thanks - yea, I bought them and had to hack them to get them in. Never even noticed the one bulb instead of two. Company offered me $12 rebate so I could reorder the right ones and take the $50 hit. I ordered the plugs that convert two plugs to one. Figured this would push the voltage to the low beam. High beam seems OK, but low beam is dim. I thought if I put in a dual beam bulb I would be OK. May have to eat this.
Should have bought these:
I just put them on my truck and it is amazing the difference they made.
Amazon.com: Dodge Ram 1500 2500 3500 Pickup Truck Sport Package Smoke Headlights Head Lamps Replacement Pair Set: Automotive
