95 ram 1500 headlight switch burnt
Old 09-18-2015, 12:34 PM
BigRedRam95's Avatar
BigRedRam95
BigRedRam95 is offline
Default 95 ram 1500 headlight switch burnt
I have been smelling a burning smell in my 95. Today I found the smell coming from the headlight switch. The lights are still working fine. Everything is stock. I have been searching and see people talking about installing a recall relay. Is the main problem with the headlight circuit or the running light circuit? How are most doing the relays? From what I see the mopar relay recall is all behind the dash but only for the running lights. Where should I buy a new switch? Thanks guys
Old 09-18-2015, 05:50 PM
Moparite's Avatar
Moparite
Moparite is offline
I was not aware there was a recall for it but not surprised. The burnt terminals/plug is fairly common. Mine burnt the running lights wire/terminal. Putting a relay on both would be ideal to keep the amperage away from the switch.
Old 09-18-2015, 06:12 PM
BigRedRam95
Well I got home from work and pulled the switch out. It burnt the headlight feed wire. I already had a relay for my 7 way trailer plug for the running lights that I never got around to hooking up. I just ran the parking lights through a relay to remove load from the switch. Now I need to get a new switch. Advance auto wanted $76 for one. I found them on ebay for 25 with the pig tail. So im going to order the switch and find a way to run relays on the headlights. Does the headlight wire leaving the switch feed down to the multifunction switch on the steering column?
Old 09-19-2015, 12:41 AM
horatio102's Avatar
horatio102
horatio102 is offline
The recall I believe was for 3500s that have more lights (and even more when hooked up to a trailer).
In my 98 I just took a headlight connector by the passenger side battery and ran my relays off that (high/low on their own).
Battery to fuse 6 to headlight switch to dimmer switch to headlamps.
Looks like the low beam is violet/white coming out of the dimmer switch, high beam is red/orange, and they're 16ga wire (if I'm seeing that right)
Old 09-19-2015, 09:38 AM
Moparite's Avatar
Moparite
Moparite is offline
I have the same lights(2500) cab lights and the three on the tail gate. I'll have to look up the recall. Changing the lights to led would help reduce load on the switch.
I'm on my third headlight switch that i got from autozone(they had the cheapest price) and obviously cheap quality! The contacts in the switch dont make contact and the lights wont come on or stay on. Lesson learned, Don't buy cheap crap!
Old 09-19-2015, 11:34 PM
horatio102's Avatar
horatio102
http://dodgeram.info/tsb/recalls/819.htm
It's only the 3500s.
Don't they also have the fender marker lights?
Old 09-20-2015, 11:24 AM
Moparite's Avatar
Moparite
Moparite is offline
Yeah, The duallys had marker lights on each of the rear fender extensions. Forgot about those.
Old 09-21-2015, 09:57 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
LMC truck makes a heavy duty harness that adds relays.
Old 09-24-2015, 11:59 AM
BigRedRam95
I think I'm going to make a set just like the LMC ones. I have all the relays and wire laying around in the shop
Old 09-24-2015, 10:15 PM
BigRedRam95
Something else I want to do. I have a set of projector lights i want to install. They have separate high and low bulbs. I want high and low on at the same time. I think all I would need is a diode and jump from the high relay trigger wire to the low relay trigger wire and put the diode in so power can only go one way.
Quick Reply: 95 ram 1500 headlight switch burnt
