Timing Set Replacement - TDC? Pic!!
So I'm getting ready to install my new timing set on my 97 5.9L and wondering what the proper way to align the marks on the cam and crank gear is.
If I align the mark on the harmonic balancer to TDC, does this align the timing chain to the correct position?
My assumtion is the line in the harmonic balancer should line up with the TDC line on the timing chain cover...is that correct?
Also, when turning the motor over by hand, does it matter which direction you turn it? Clockwise or counter clockwise when facing the front of the engine?
I've always just removed the cover , and balancer , then lined up the two marks on the OEM chain gears before removing the chain , then simply slide off the old , and slide on the new . Never failed me yet . You should have some instruction on lining up the marks with the new chain . Just get the old to line up with that and go
Did my chain today. Cam gear at 6 oclock and the crank gear at 12 oclock. TDC should be on 1 cylinder. If you want to know what stroke it is on just take off the cap and look at the rotor. If its pointing towards the 1 sparkplug wire contact then its the compression stroke. If its pointing in the opposite direction then its the exhaust stroke. It was easy for me cuz I had the plenum off.
