Would being able to rotate the driveshaft from 12 o clock to about 1:30 be to much rotational play? I cant remember how much play it had before I took it off.
I think a 1/16th to an 1/8th of a turn or so is to be expected, even with all new parts, much more than that, and you need to see where its sloppy. If its just the spiders, it is prolly fine, if it's pinion to gear clearance, that needs to be addressed.
