Harmonic Balancer - Shot or OK? Pics!
So I just pulled my harmonic balancer out, and noticed that the rubber piece between the two metal pieces is pushed in on one side, and popping out the other in one spot.
Is this normal for the HB?
Or is this signaling its time to replace it before it goes out completely?
Thats what I was thinking....
Is the HB one of those items you want to use an OEM replacement?
All of the aftermarket ones appear to be identicle with the pulley permanently attached, and the Dorman brand seems to be the most readily available (I know Dorman is not a popular brand on here haha)
Agreed. I've been reading that the Dorman ones arent the correct size and cause the belt to pop off unless you shim the alternator/ac bracket with some washers....my oem one will be at the dealership tomorrow morning... thanks for the help!!
