keyless entry problems??
2001 ram 1500 sport, 5.9 w/ 4sp auto 4dr ext cab.
So I've done some research, and due to the common 4th gen key fob problem, thats all thats come up...
Anyways, I have been having a problem ever since i bought my truck with the keyless entry, it seems to be not working well. it doesn't work unless i hold the fob right beside the door, up near the lock, even then it usually takes a few presses of the button. even when it works it seems like barely, the lock comes up enough to unlock it, but i can still pull the lock up another 1/2 inch.
I did pull it apart, and then it seemed to work for about a week. it stopped working and i replaced batteries and that didn't fix it, so not sure whats going on here...
Is there a receiver for the fob that actuates the power locks that can go back? the door switch works as it should. Anyone have any ideas? its pretty annoying...
On the key fob issue, my truck has a sticker on the rad support that says something like "warning, this truck is equipped with a remote start feature, disable before working on" blah blah blah, does this actually mean my truck has the remote engine start feature? my key fobs are aftermarket and the engine start doesn't work, but neither does my door unlock work very well. does anyone know about that one?
Thanks in advance guys!
Wonder if they are just weak transmitters..... With new batteries, you should be able to unlock your doors from inside the house..... Might be worth seeing if you can find a factory FOB, and have it programmed. (which, with a working fob, I think you can program additional ones.)
It sounds like the door lock mechanism is degrading. The alarm system just sends a signal to the component to actuate.
Trending Topics
You have an aftermarket installed alarm based on what I underlined in your post. Any other stickers on the truck? Previous owner might have put them on to indicate such and then you'd get the brand.
And range does effect it I guess. The only time I can get the doors to unlock with the fob is if I'm within a few inches of the door, and I usually have to click the botton a few times
