Hughes/edelbrock FI Airgap
Any one mod will not be a big change in any aspect... it is the use of complimentary mods together that get the best improvements.
I doubt 16mpg is a realistic goal for every day... at best you might get there with all the right parts and a deliberate mellow drive.
I know I feel good about getting 15, as most around here report 14 as good, 10-12 as common, and complaints start when 8-10.
The AirGap is designed for improvements at higher RPM, and is (by itself) a loss at lower RPM... but with other mods this can be offest.
If you goal is purely MPG and you want to maintain low end (where it is mostly driven), just do an aluminum plenum plate (Hughes, eBay, etc), and save your money.
As I said, I'm getting 15mpg with an AirGap, but as best as I can tell, the AirGap lost me 0.75.
The single best improvement I did for mpg was the HemiFever tune, gaining 2mpg.
I barely noticed a half mpg gain when I installed it but my plenum was shot pretty bad. The best mpg boost I got for the least amount of money was a new timing chain that got me .75 more mpg. I started at 10.1 mpg when I bought it. With the lift and larger tires I range from 13.5-14.2mpg.
Trending Topics
This manifold starts coming to life at ~1,800rpm and over 2,000rpm is happily doing it's thing.
