Replacing front u-joint, question on hub "seal/shield"
I'm in the process of replacing the rotors/pads on the front of my '96 4x4, and there was also a click from the driver's front wheel which I tracked to a bad u-joint.
I finally got the hub off last night and removed the axle to get the u-joint out. The u-joint clips were really rusted in place, but an air chisel and lots of PB Blaster helped get those clips off and let me remove the u-joint. Reassembly will start this weekend.
On the outer axle (that goes through the hub), there is a metal lip/shield/seal where the axle meets the hub. This is the original axle stub, so that lip/shield/seal is corroded and slightly deteriorated. It looks like it slips over the end of the axle stub, but I can't find where it is available as a separate piece for replacement. I think if you really want to replace that, you have to replace the axle stub - anyone have BTDT experience with that lip/shield/seal? I'm thinking that I should be OK to reuse the axle stub as-is, but just wanted to see if someone else has experience. A picture would help here, I know, so I'll try and add one to this post tonight.
Also, are there thoughts on what-all surfaces should get anti-sieze (regular or copper-based) when I reassemble everything? I'm thinking the hub to steering knuckle surfaces and the stub-axle to bearing/hub surfaces, as well as where the u-joint fits in the flanges.
Lastly, anyone have a good source for new brake rotor shields?
Thanks!
Thanks!
