Speakers Are not working.
I agree with the above replies...However, most aftermarket head units have a blue trigger wire (operates the amplifier or power antenna). If in fact you do have the Infinity sound system (should indicate that on the speaker covers or factory stereo) this wire is used to power the factory amplifier. Without power to the amplifier the speakers will not work.
Front Infiniti speaker filter/amps
[QUOTE=Warlock_III;3281727]I agree with the above replies...However, most aftermarket head units have a blue trigger wire (operates the amplifier or power antenna). If in fact you do have the Infinity sound system (should indicate that on the speaker covers or factory stereo) this wire is used to power the factory amplifier. Without power to the amplifier the speakers wil
not work.[/QUOTE so I cut Amp wires at 6x9 and put Kenwood 5 ways in my 94 ram due to a high pitch squeel as I volume up like passed half volume well sounds great still squeels but at higher level I'm guessing ground wire but ima put complete new stereo I wish it had room 4 a double din deck
[QUOTE=Patrick paintinsht;3547165]
There are kits out there in the world to alter your dash so the double din will fit, and look basically stockish.
Trending Topics
