2000 ram 2500 reg cab parking brake tensioner/equalizer
I had to change my parking brake cables a while back. The extension cable is sometimes used depending upon the length of the frame/truck and is only used on the main cable coming from the parking brake pedal. I went with aftermarket parking brake cables that went to each rear wheel, in addition to the extension cable. Once you look at the lengths available online (Advance Auto, O'Reillys, etc.), you can get under your truck to take a measurement to determine which cable will fit your needs. The equalizer/adjuster was and likely is still available thru the dealer. I had to go through this exercise when I swapped from a drum brake Dana 60 rear to a disc brake Dana 60 rear from a later model 2nd gen truck.
