Need help with 46re transmission
Old 03-11-2016, 07:17 PM
Creeves's Avatar
Creeves
Creeves is offline
Smile Need help with 46re transmission
I replaced the solenoids and the speed sensor and output speed sensor. But my transmission is still shifting at 3000 rpm. 1st to 2nd gear is 3000 rpm and second to 3rd is 3000 rpm but after 3rd it shifts fine.... PLEASE HELP
Old 03-11-2016, 07:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
How's the TV cable? Adjusted too tight, or sticking, perhaps?
Old 03-11-2016, 07:32 PM
Creeves's Avatar
Creeves
Creeves is offline
Well I've adjusted it to the factory specs and no change.. So I adjusted way tight and way to lose to see if there was a difference.. There was no difference
Old 03-11-2016, 07:48 PM
zildjian3707's Avatar
zildjian3707
zildjian3707 is offline
bands
Old 03-11-2016, 08:17 PM
Creeves's Avatar
Creeves
Creeves is offline
The bands didn't look wore out when I replaced the solenoids.. Just normal wear. But I thought I should adjust them just to see what would happen.. Which one needs to be adjusted?
Old 03-11-2016, 08:20 PM
HeyYou is offline
Both. I think the front band is for reverse.... (the one you need to be inside the trans to adjust) I think....... Can try doing the easy one first, and see if it makes any difference.
Old 03-11-2016, 08:23 PM
Creeves's Avatar
Creeves
Creeves is offline
Yea thats what I thought. I really don't wanna drain the tranny again.. This will be the third time
Old 03-11-2016, 08:29 PM
HeyYou is offline
install a drain plug.
Old 03-11-2016, 08:33 PM
Creeves's Avatar
Creeves
Creeves is offline
Yea I thought about it but it took most money of what I had to buy the solenoids and fluid and filter
Old 03-11-2016, 08:36 PM
HeyYou is offline
Next time around then.
Quick Reply: Need help with 46re transmission
