Seat belt and CTM clicking
Old 04-29-2016, 12:33 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Default Seat belt and CTM clicking
My dads 98 has had a dying battery issue for a while, he assumed that it was a bad battery and just jumped it when he uses it to haul the trash off. That isn't the problem.
I jumped the truck the other day to move it out of the way and it wouldn't stay running (IAC valve stuck most likely). after it died the second time I tried to jump it I heard a rapid clicking from the seat back and where the CTM is. I unplugged the pigtail under the driver seat and that shut the seat up but the CTM was still clicking.
I'm thinking it's the SCTM under the center seat or the seat belt solenoid but why would the CTM be clicking also?
The seat belt fuse is good and I gave up pretty quick on trying to pull the IOD fuse when it didn't want to pull out.
One of these days soon I'm going to do the test on the SCTM that I found online, I just haven't gotten back over there to do it yet.
Old 04-30-2016, 07:16 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Find the body grounds either in the kick panels or near the air bag module. Make sure the grounds are tight first.
Old 05-04-2016, 08:54 AM
Sheriff420's Avatar
Sheriff420
That's a good point I'll check it out the next time I'm at my dads house. I think I remember reading something about a poor ground causing the issue.
Quick Reply: Seat belt and CTM clicking
