Air conditioning issue(s)
Old 06-16-2016, 06:24 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Default Air conditioning issue(s)
So 3 years ago when bought my truck I quickly learned about the "wild vents" as my truck would blow out the defrost vents at WOT.
I got that fixed and the AC has been solid since.
Tuesday as I was leaving the Hot Rod Power Tours stop in Grand Prairie my air went straight to the defroster and it hasn't blown out the front vents since then.
I just got around to looking at it today and I have verified that there is vacuum at the line going into the firewall. That is my extent of the knowledge on this.
So what should I check next knowing that I have vacuum going into the firewall?
Old 06-16-2016, 08:21 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
See if you have vacuum at the control head. That involves pulling it out of the dash......
Old 06-16-2016, 10:17 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Is that the block of climate control ***** or something else..?
Old 06-17-2016, 12:06 AM
Friar Tuck's Avatar
Friar Tuck
Friar Tuck is offline
Lightbulb
the controls
Old 06-17-2016, 05:42 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
No vacuum there..
Old 06-17-2016, 06:11 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
If I pull the vacuum line that goes into the firewall and try and blow into it nothing gets through.
This is the little plate inside the black "thing" that all of the vacuum lines hook to one the back of the AC controls
I'm thinking some of that gunky **** may have gotten sucked through that black vacuum line and clogged it
Thoughts?
Old 06-17-2016, 06:14 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
If you look where the black line goes into the orange thing there is some white residue where it looks like some of that stuff has been sitting...
Old 06-17-2016, 09:08 PM
HeyYou is offline
See if you can clean it out. Then check and see if you actually get vacuum there.
Old 06-17-2016, 09:19 PM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Is that black line in the back of the orange connector the same line that comes through the firewall?
Old 06-17-2016, 10:01 PM
HeyYou is offline
I do believe so.....
Quick Reply: Air conditioning issue(s)
