I bought a set of performance links for my gen 1 dakota and they were too long so I ended up using my original links. So are you needing something longer or shorter because I have some long ones I don't need.
Do you have access to a welder? The links are fairly easy to shorten and/or modify. Time to create a franken-link. Cut off the two halves that you need, to the correct length and weld them up. If you can, if try are both the same diameter, sleeve them.
