A/C issue
A/C issue
So I got my 94 dodge 1500 5.9 360 ac system drained vacuumed and filled. No leaks or anything. Blew somewhat cold upon completion but after about 20 minutes it starts blowin hot air. Ac clutch is spinning and working. My high and low lines are cols but blowing hot in cab. I'm stuck on defrost mode but when I pull down on the vacuum operated plunger behind the dash in order to get it to blow threw vents it still blows hot air. Please help
Temp door. It's cable operated on your truck. You should be able to find the bottom of the axle it pivots on just above the trans tunnel, towards the passenger side. (hope you have a secondary occupation as a contortionist......) Put your finger on it, and turn the temp **** from one extreme to the other. Does the axle move?
Download the service manual for your truck. (I think the 94 link is broken, so, grab the 95, it's the same thing.) Get it here. There is a procedure for adjusting the temp cable, hopefully, that will solve your issues. (It's also posted here in a couple spots, a search might turn it up.)
