98 Ram 1500 (4x4): Need to narrow down the possible problem, pleas read
Old 08-29-2016, 11:47 AM
Fawn Brigman's Avatar
Fawn Brigman
Fawn Brigman is offline
Default 98 Ram 1500 (4x4): Need to narrow down the possible problem, pleas read
I have a 98 Dodge Ram 1500. The truck idles fine and runs normal, until about 40 mph and will shake and sputter like it isn't getting enough gas until it reaches about 50 mph and will resume normally. But, if I accelerate quicker it won't do it and runs great. I have had about 3 different "reasons" and none of them are alike, needing it narrowed down. Anyone else deal with this?
Old 08-29-2016, 11:55 AM
dbbd1's Avatar
dbbd1
dbbd1 is offline
What has been done to the truck so far? What were the "other reason" that did not work?
Automatic or manual, what size engine?
Old 08-29-2016, 12:00 PM
Fawn Brigman
Coil Packs, Fuel Injectors, fuel manifold, wheel bearing. I haven't done anything to it yet, with so many "suggestions" I wanted to narrow it down. Automatic, 5.9L
Old 08-29-2016, 12:27 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,166 Likes on 2,920 Posts
Check the plenum. (see stickied thread at top of this forum.)
CEL on? Any pending codes?
Unplug the front O2 sensor, go for a drive. anything change?
Using any oil? Still have your cat?
Old 08-29-2016, 01:05 PM
Fawn Brigman
None of the symptoms from the Plenum thread seem to apply. No issues with oil, no knocking, doesn't have issues with hills.
No CEL, still have CAT.
I will check the O2 tonight.
Old 08-29-2016, 05:01 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
I am not too well versed on trans issues, so does anyone think that this could be trans or flex plate issues?
Old 08-29-2016, 05:15 PM
HeyYou is offline
Don't think so, that would tend to get louder/more annoying as engine load increased. (like, going faster....)
I suspect an engine miss....... but, we'll get to that if/when we need to.
Old 09-05-2016, 09:51 AM
Max Pressure's Avatar
Max Pressure
Max Pressure is offline
Sorry but I don't see the plenum "stickied" thread here, how can i view that? I'm interested in seeing this issue through ...
Thanks!
-Max
__________________________________________________ __
98 Ram 185K mostly all stock ...
Old 09-05-2016, 10:03 AM
HeyYou is offline
Right at the top of this forum. Here.
Old 09-07-2016, 10:10 AM
Brian in Tucson's Avatar
Brian in Tucson
Brian in Tucson is offline
I had a Chevy Lumina (ptui!) with an intermittent miss, it ended up being a marginal spark plug wire. I think I'd do a fairly comprehensive tuneup: plugs, wires, cap & rotor, and air cleaner and see what happens.
BTW, welcome to Dodge City!
Quick Reply: 98 Ram 1500 (4x4): Need to narrow down the possible problem, pleas read
