Can I get a second on this
There are a lot of free programs out there...... You pay for the cable, and software comes with it. I have OBDWiz, but, am thoroughly underwhelmed with its performance. There are very few parameters that it actually lets you monitor. Its good for reading codes, but, that's about it. Haven't tried any others yet....... Looking for software that will be compatible with my Bluetooth OBDII device.
Engine barely ran when I got this truck, so it's hard to say if this problem existed before crank sensor was changed. As the crank sensor is so much fun to get at I ordered the ScanTool software and will wait until I see what that shows me.
I'll be able to freeze frame what the crank sensor is doing at the time it's misbehaving as well as all the other parameters that might be contributing. Hopefully, I can isolate that way.
I changed the crank sensor because it just jumped out at me while I had the exhaust off and it still wasn't easy but time to hopefully stop shooting in the dark.
Hooked up my obdwiz yesterday. Still trying to figure out how to use this but I think I already see it's limited. Does not appear to have the ability to check/set the fuel/cam timing which I had the shop do.
Below are two snapshots of the PID Monitor. The first is with the idle at 1500 in park. Engine was stumbling badly and kept it that way for longer than normal. Noticed odor and occasional I think pop in the manifold.
The second is idle at 1500 in drive with foot on break. Misfire stumble mostly gone and holding steady. No odor or popping.
Again, this thing drives fine as long as I stay off a no load light cruise.
Well got truck back from shop today and still have the problem after fuel sync done. It seems to run a bit better and the problem seems to be harder to produce but never the less still there.
The shift points prior to having the fuel sync done, seemed weird to me and it was hard to get it to downshift but that seems much improved now. Bringing idle up to 1500 in neutral still stumbles and misses as before. Slight gas peddle in a mostly coast situation produces a buck or two but other than that, it's perfectly drive-able and you wouldn't notice a thing.
Just don't get it. I know cheap crank sensor was mentioned. It was a CarQuest brand that I've used many times before without issues. I'm unfortunately familiar with conditions associated with bad crank sensor and this just doesn't seem to fit considering it only flakes out under this specific condition.
I'm considering getting OBD2 software that I can monitor while I'm driving as well as double check the fuel sync. Is there any that would fit this bill around $100 or less?
BTW it doesn't do it when I first start the truck in the am. Kicks in about halfway into the warm up cycle.
