1500 brake upgrade
1500 brake upgrade
Reading around old threads I have a little confusion on upgrading my 99 1500 brakes.
For the rear, do I use Chevy or dodge wheel cylinders?
- are they supposed to be for a 2500 or 3500? Is there a difference?
For the front. Do i just need 1999 2500 calipers or do I also need the brackets? Are the pads the same as my current ones?
Will the upgraded calipers clear my 15" rims?
Thank you. My right front caliper hangs up after the truck sits over night. I'm pretty sure its a collapsed brake hose but I wanted to upgrade the brakes anyways. The only thing stopping me was being unsure if my rims would still fit.
We should sticky the brake upgrade info for future purposes. Maybe a diy?
I'm not certain if the 99 is the same as the 98, but;
Front use 2500LD calipers (80mm bore), 1500 disks and pads.
2500HD calipers are twin piston and have a different mount.
Rear use 2500HD/3500 cylinders (28mm bore), 1500 drums and shoes.
Use GM3500 if you need more (30mm bore).
Stock front is 75mm bore, rear is 24mm bore.
Following this... Almost ate the *** end of a Silverado on the highway and I was standing on the brakes too, actually hurt my leg. I bet I missed him by a hair. First time Ive noticed anything with the brakes and now it seems to lack stopping power with normal stop n go on the side streets. Only had the truck since July2016, so guess I better dig into the brakes and see whats going on soon. I may upgrade, just checked on parts everything runs around $20 except the rotors and drums. I like the upgrade idea.
use stainless braided lines, supposed to be the best.
Trending Topics
